Didn't look at that tonight. I adjusted the rockers and buttoned up a couple other things. Is it normal for roller rockers and beehive springs to make some noise? Doesn't sound like anything bad, just sounds like them going up and down.
Just thought of something, maybe a couple pushrods are rubbing the guide plates. Don't know, never had roller rockers or guide plates. They are magnum heads, with a set of roller rockers from Hughes (not the aluminum ones on their website, they are stainless PRW rockers) with beehive springs. Cam is a Hughes 3742AL, so with the 1.65 rockers, the lift is at .607/.612 and 237/242. The cam has more lift than any cam I've had too, so I don't know if the sound is normal. It's not a tapping or ticking, kind of sounds like a bowling ball rolling across concrete or something. Hard to explain.
