MoparBrit
HillingdonDart
Doing the trans filter today. Got the thing drained and pan off & cleaned. Have a '71 Dart /6 with a 904 auto. Got the FT1039 Fram filter kit. Looks like it is designed to work with 904 and 727 as two gaskets supplied.
Have verified that it is the correct kit, but here is the issue. The filter is different than that on the car. Same mount, but a bit larger in size. The main issue are the holes in it. I've taken a picture of the two for you. Is it okay to use this filter?
Cheers
Cheers
