AdamR
Big Member
1wild&crazyguy just likes to stir the pot. No worries. The only stupid question is the one not asked.
I still 'like my original post' recommend to start with stock heat range plugs for a 340.
which would be an autolite 65
Dont worry,being a guy,I feel I sometimes ask questions that I should know also,its all relevant.:toothy10:Ive worked on and been around older cars my entire life,I dont know everything about them but I love learning.thanks for the lack of bashing
i guess the boys are still intimidated by girls
I wanna try NGKs next time I change the plugs.Ive heard nothing but good things about them.I've never had a problem with NGK. They are a good plug.
i will start there and update where how i make out.It sounds to me as though the idle mixture is too rich and the squirters are too small. First I would adjust the idle mixture when warm and in gear to the highest possible vacuum reading. If you have have to screw the idle mixture screws almost all the way in, you may have a blown power valve.
Next, if it is bogging at no load, I would bump up the squirter size and see how it runs off idle from a dead stop. Then comes top end WOT throttle testing in a safe place.... This will be how you determine your main jet size.
I haven't been terribly impressed by the Autolite plugs. My favorite is the NGK GR4GP or "G-power" plug. The slightly more expensive V-power plugs burn up too quickly, but run extremely well before they do. NGK plugs are available everywhere.
I believe I´ve read on the NGK site that for every 70-100 you increase the power you should be 1 step colder on the plugs.
Also read that it´s safer to start with a too cold plug than a too hot..if you´re not sure what to use.
Anyone more experienced than I who can confirm or deny...?
I´m running NGK R5670-6 in my 383, 10.2:1, MP 284/484 cam.
I'm gonna echo Adam here and suggest similar advice but not just towards you ''Justain'', but to everyone not directly helping the thread.
