On the intake side, it looks like incoming air is going to ramp up into the guide. Exhaust, looks like air needs a ladder to climb out and slide down the hill out of the port.
Not to be silly but have you lined up head/exhaust/intake/valve cover gaskets to make sure bolt holes are in the right spots?
Do have a real question though... i saw a video saying how W2 heads are the greatest thing to ever exist and the upgraded exhaust port makes the world a happier place.. if the W2 port is so much better why do aftermarket guys use a stock shaped port?
AHHHHH... that's right.. he did mention the moved exhaust bolt to make the port wider.. i should have known from that.. sorry i'm having a dumber day than normalEdelbrock heads and Speedmaster heads are and have always been built for the street, street strip guys which is smart. They want to pull off their stock exhaust and install them and easily bolt a header on. W2 heads wisely moved the bolt holes out so they had more room to shape a port. But how many sets of used W2 headers do you see out there. I would like to talk to this know it all and have him explain how I can run 9.30’s with Edelbrock heads maybe 9.20’s with Edelbrock heads. It’s not all about flow numbers on the exhaust side.
@PRH its been forever since I’ve had a set of out of the box “complete” finished Edelbrock heads. Looking at these pictures do you see anything that would be finished a little nicer than these heads. Are they this bad because he bought them bare.
I dont know enough to comment. But Im reading Sir.Wow not much interest or feedback here.
The “bare” heads come unfinished.
That means unfinished guides, seats, bowls.
It is not really the same thing as an “assembled” head with the parts taken out.
The first thing I do with the bare heads is fit the guides and cut the seats.
Im sorry man, I ain’t smart enough to articulate my thoughts on this type of stuff. I just saw a lot of sharp angles and what seemed like raw surfaces that could have easily been cleaned up. Watching and learning as always.Wow not much interest or feedback here.
