pishta
I know I'm right....
Show us your Harbor Freight fails. Hate to love, love to hate.
6 ton bench press. Dont waste your time with anything bigger than driving bushings. The working distance is too small for a piston and the press bar is too long for any type of load, it just kicks out the jack, bending the solid steel bar (and I even replaced the Chinese 72mm(?) bar with a good American bought 3/4 steel bar that was probably cast in Korea) and I still bent it. Must have just overloaded it. What kind of pressure does it take to press a pin out? I think I saw a 10,000 lb spike on a good 30 ton hydraulic before it popped and pushed the pin out? I think the ram needs more support, like 2 bars running parallel to the ram, going through the bed plate welded top and bottom like rails. no more kick out. :wack:
