got the broadcast sheet got most of the codes decoded and did find some stuff out that we didnt already know original 318 2 bbl,original torqueflite 904trans, original 8 1/4 rear, one tire fryer with 2.45:1 rear gears, original big bolt pattern brakes,d78x14 WSW ???? 14'' white wall?,Y97gasoline 3 gallons?? mono tone paint,bench seat,carpeting,10x2.5" rear drum brakes,Front disc brakes some years power,tinted glass all,50 amp alt,46 a/h battery,3spd variable wipers,inside hood release,music master radio am,coolant recover system,Noise reduce pkg.,stan.1" frt. shocks,Rear shock. absorber later,power steering, that is what we can get so far there are some codes missing from this list cause the decoder didnt have them so if anyone has a good decoder could you post it thank you.
