mopar56
Yes I did, nothing there and with the orings it just slips together no issues.Have you looked into both tube holes in both bowla to confirm there aren't some old o rings or seals stuffed up in them?
Why not use the o rings, then?Yes I did, nothing there and with the orings it just slips together no issues.
You got me wonderin now if the tubes aren't different lengths on them.Well I am now but the seals look more robust so I thought I'd try them, maybe they just won't work on the older 1850 series? The o-rings didn't leak last time so I guess I'll just do it they way I did before.
They almost have to be. I've never had a problem with the cup type seals. I have a QFT 450 on Vixen and that's what's on her carburetor and I've changed them before. Easy peasy. So I bet that's what it is.Well thats what I was thinking, the Holley kit i got fits a multitude of applications and it came with the seals AND o-rings, i remember I couldn't get the seals to fit the first time but I thought I'd try again, i mean I'm a 210 pound guy and I used all the force I had pushing against that bowl, I honestly thought the tube was going to bend, if you find out I'd like to know but for now the o-rings are in.
Flooding is either a needle and seat issue of a bad float.... Bad brass floats are easy to spot, it'll have gas in it... Nitrophyl check the weight compared to a good floatYes, that is what I did today AND previously when I assembled it and installed it, no fuel leaks at all, Just flooding.
Thankyou, i did watch several videos on this, a couple were from a Holley executive, but what I understand is that the start point is to set them static with the bowl inverted and the float level with the bottom, ( well top actually as it's upside down at this point ) of the bowl, which is what I have done however if I understand you correctly you are suggesting otherwise, doing it your way will there be enough fuel in the bowls for the engine to start and run while I do the adjustment?When you reinstall the needle & seat assemblies lube the o rings, then screw them in deep enough that the nut barely has anything to grab... That way when you start the engine you'll know the fuel level should be low.... So, with the sight plug out and a screwdriver & 5/8 wrench you can slowly raise the level... If your careful you can do it with the engine running, back the lock screw off slightly so fuel weeps but not so much that it becomes a serious leak... Turn the nut one flat & snug the screw... Let the fuel level stabilize... Repeat till the fuel level is at the point it just trickles from the sight plug hole....
If your pulling the bowl off then yes, flip it and look at the float, however I tend to intentionally set it a touch low so I know I need to rise the level when the engine is running....Thankyou, i did watch several videos on this, a couple were from a Holley executive, but what I understand is that the start point is to set them static with the bowl inverted and the float level with the bottom, ( well top actually as it's upside down at this point ) of the bowl, which is what I have done however if I understand you correctly you are suggesting otherwise, doing it your way will there be enough fuel in the bowls for the engine to start and run while I do the adjustment?
You said lube.When you reinstall the needle & seat assemblies lube the o rings, then screw them in deep enough that the nut barely has anything to grab... That way when you start the engine you'll know the fuel level should be low.... So, with the sight plug out and a screwdriver & 5/8 wrench you can slowly raise the level... If your careful you can do it with the engine running, back the lock screw off slightly so fuel weeps but not so much that it becomes a serious leak... Turn the nut one flat & snug the screw... Let the fuel level stabilize... Repeat till the fuel level is at the point it just trickles from the sight plug hole....
You said lube.
They are...the tube on certain Holleys is too long to fit with the seals...you have to use the o-rings...You got me wonderin now if the tubes aren't different lengths on them.
And there you have it! Glad I stopped pushing, lol thanks for the info!They are...the tube on certain Holleys is too long to fit with the seals...you have to use the o-rings...
...and yes, the o-rings on the needle-seat assembly need to be replaced if hard...will cause flooding no matter how far you screw the assembly in...just went through this on several Holley's lately.
You could take a tubing cutter and shorten the tube up.And there you have it! Glad I stopped pushing, lol thanks for the info!
