65TerrorCuda
I been ale:uke:very under the weatherale: lately but getting prepared for summer never the less. this Setup is for my 74 Plymouth Scamp that I am working on Slowly at the moment. It is still a 1 barrel carb but have a 2 BBL Manifold and Kickdown coming soon.
65terrorcuda: I think it has the 904 transmission but unsure and yes I do want the Cable Kick-down set up which Frank said its better. .
How about this part, do I need it as well. http://www.holley.com/20-91.asp
So here is what I learn so far thats needed to make this set up work:
Lokar KD-2904HT Kick down Kit: http://www.summitracing.com/parts/LOK-KD-2904HT/
Lokar TC-1000U Throttle Cable: http://www.summitracing.com/parts/LOK-TC-1000U/
Mr. Gasket 2 barrel Adapter #1937 : http://www.summitracing.com/parts/MRG-1937/
Holley Throttle Lever Extension #20-7 http://www.summitracing.com/parts/HLY-20-7/
Holley 500 CFM 2 Barrel Carb
If you're going all-cable, you won't need the lever extension. Both cables will match up to the universal throttle lever. You may have to make a spacer to move the lokar bracket a bit away from the carb to prevent the cables from making too extreme an angle on the 2bbl, as the bracket is intended to be mounted to the rear carb bolt of a 4bbl. I used a small square of 1/4" steel with two holes drilled in it. A better solution would be a fancy cable bracket, but I don't see one that will work ideally with the 2bbl...
Like these:
http://www.summitracing.com/parts/LOK-TCB40BG/?rtype=10
http://www.summitracing.com/parts/LOK-TCB-40DQ/?rtype=10
I'm using the "avs" one on an AFB, and it's better than sliced bread.
Hope you are feeling better :sad4:
