Well I was thankful to see they got better from the first time slip you showed...LOL Reaction times Sucked.......Less....... with the proform.
My 1.767 60' run, I was told by a friend that i had pack the front wheel!
Handed him my gopro and say PROVE IT! He was unable to do so.
Lol that was not mine. That was the reaction of the dragster. All my runs were in the Left lane.Well I was thankful to see they got better from the first time slip you showed...
when I seen the first time slip all I could think was hey wake up it's time to go LOL... But the last one .014 that's ok......
with the car shading the wheel you can't see it. BUT in the slo mo you can see the front Wheel slow just for a moment.LOL Reaction times Sucked.......Less....... with the proform.
We all know pic are hard to read a plug. but i haven't pulled a plug in a while so i will do that.
think i still have one new plug so cutting off the threads of one should be now problem.
Explain to me again what "T slots do and where you install them and what it accomplishes.
Ok i was thinking that it was some screw you drilled in to the transfer slot in the bore. You know the the one you set square in the bore with the butterfly
also no drilled and tap for the PVCR
Pic on the way but one question
how does restricting the transfer slot help make the booster come on sooner or transfer hold on longer.
View attachment 1715549730 View attachment 1715549731 I also did a video with my phone. don't know if i can make it work.
But if not, here is a couple more pics
To big of a file so i updated to YouTube
Removed video, so you didn't have to here me say bad words LOL
But mostly because it was blurry even in full screen. pics are better.
Bad words don’t scare me!!
Ok you can get a laugh out of it but the video Q Sucks!Put the video back up!!!! Bad words don’t scare me!!
View attachment 1715549771 View attachment 1715549772
so i was able to come up with a couple new plugs
so i cut the other one up as well.
left is #1 and right is cyl 2
That damn thing had an 850 venturi and 1.688 throttle blade.
Holley 9381.
At some point, the 1.560 x 1.688 configuration became the NASCAR standard sizing.
The Street HP 850 also uses that sizing.
Not a fan.
The thought of racing me at the track does.....nothing scares you ROSE ;)
Careful cudafever gets a little jumpy if we veer off track on one his threads......Good one! You owe me lunch now LOL.
