hood pins on dusters
69DARTS
69 Darts Rule
indiana
lets see pics on the hood pins on the duster demon
any instruction on where to drill holes on hood and core support
thanks
Here is mine. Very simple to install.
need to see underhood pics
You know where those circular bumpers are at the front of you car along the rad support? they should be right around there. They are just indents in the rad support. Sorry, I dont have any pics sadly
Here's mine and they were on the car when I bought it but this is for a full bolt on fiberglass hood also.
The pins bolt to the fender, not the actual core support. There should already be a hole next to the hood bumper/stop for the pin. And on the underside of the hood there should be a hole precut from the hood-bracing. I can get pics. for you of my car tomorrow if you'd like.
Dusters and Darts are in different locations. I've posted the following pics in some other thread regarding the same subject.
Here's the pics, and if you need anything else, just ask.
From the front of hood
From the inner side of fender
From the saddle
From the side
The same pics, with the measurements are here in post #8 http://www.forabodiesonly.com/mopar/showthread.php?t=61158
All the best!
Giles
thank u
