I do know (so I've been told) that the engine is original to the car but the transmission is not (it was a 3 spd car) so I think pilot bushings should be ok. Again I'm going to have pull it and seeWhen you say you can't find neutral, do you mean the gears grind when trying to go into gear with the clutch depressed, if so I ran into that when I swapped in a crank that had the tranny pilot shaft hole drilled to depth, but as I found out later was not honed to size, the crank pilot bushing seized on to the tranny input shaft and kept it spinning even with the clutch pedal down.
