BTW rat patrol that is a gnarly looking setup you have. cant even tell its a 318. how much if you had to guess is tied up in that build?
Not my build Cowboy..my engine builders ex- rig. (Mine's just a low 12 sec 392 stroker.)
I wouldn't like to comment on cost as its not my engine.
A lot of the fabrication was done by a mutual friend who has now passed on (ex Nascar mechanic) - Runs a Wolf 3D EFI and Twin master power turbos which is where the $$$ are.
- [FONT=Verdana,Arial,Helvetica,sans-serif]318 block, 8:1 comp, Eagle rods, KB Hyper slugs, 360 heads[/FONT]
- [FONT=Verdana,Arial,Helvetica,sans-serif].525 lift Wade solid Cam.[/FONT]
- [FONT=Verdana,Arial,Helvetica,sans-serif]Twin Master Power TO4 Turbos running 3 stages of boost; 7 /15 / 21 PSI.[/FONT]
- [FONT=Verdana,Arial,Helvetica,sans-serif]Twin carter electric fuel pumps[/FONT]
[FONT=Verdana,Arial,Helvetica,sans-serif][/FONT]
- [FONT=Verdana,Arial,Helvetica,sans-serif]Home Fabricated EFI plenum mounted on a Weiand Tunnel ram base intake with Bosche injectors.[/FONT]
- [FONT=Verdana,Arial,Helvetica,sans-serif]Contoller is a Wolf 3D computer with a Crane Hi Six ignition[/FONT]
- [FONT=Verdana,Arial,Helvetica,sans-serif]The 3rd member is a Ford 9” using a Strange Full spool with 31 spline axles.[/FONT]
- [FONT=Verdana,Arial,Helvetica,sans-serif]Traction is managed by a Pinion snubber, reversed spring hangers and Caltrac style bars[/FONT]
- [FONT=Verdana,Arial,Helvetica,sans-serif]Stoppers are Ford front callipers with 12” rotors with a Rack and Pinion front end conversion.[/FONT]
- [FONT=Verdana,Arial,Helvetica,sans-serif]Trans is a 727 with a 2800 stall.[/FONT]
132 MPH at 11.0 in his car.
Engine is now sold. Made 10.2 at 134mph last run.
Not a half bad "318" LOL!!
PS - Sorry to the OP for the OT - but a single turbo is a great idea if you know someone who can build it.
