MOPAROFFICIAL
Oogliboogli
Where is Op located exactly? I'm in Oceanside and pass through LA to the valley about every month. I might be able to drop by with my installer and pop them in.
ifth
if the can turns freely run it , cam bearings can look like hell and be good...
didnt see a crack, only thing that would worry me on that one would be if it could come completely loose and get loose in the engine ...When you see a crack like this in one of his bearings the discussion is over. The bearings need changed out
You are correct but if the damage reaches past the edge from the oil hole you will lose some oil pressure. I'd replace them, Better safe then sorry.ifth
To install the cam with the engine out, first install the crank. Then I like to stand the block on its butt on 2×4s laid on their side. With the block level it is easy to drop the cam gently straight down without knicking a bearing. Then you can install the rod and piston assemblies while watching and guiding the rods over the crank.I am thinking so. It’s my first cam swap and I read “don’t scratch the cam bearings” like 1000 times. Used a bolt and everything but that is like banging on sh&t damage
Crack? Hard to say but more likely a scratch to the edge that has been bleeding oil and eroding the bearing. It is apart so just install new for peace of mind.didnt see a crack, only thing that would worry me on that one would be if it could come completely loose and get loose in the engine ...
You take the cam to the shop installing the bbearings so they can verify free rotation. Then you need the cam out to clean the oil passages and the whole block before reassembly. I like to stand the block on the bell housing end to lower the cam in. It should rotate easily with the index finger and thumb.Maybe the camshaft tunnel is not straight the machine shop can tell
