Any tips on re-assembly of bolts that have been painted? How do you keep the paint from chipping?
Better yet. Eastwood sells some plastic, 6 sided inserts that go inside your socket. The 1/2 inch insert 'pops' into a 9/16 socket. They are cheap, and they work really well.
I take a piece of cardboard and punch a bunch of holes in it and shove the bolts in and paint them with VHT, then after they dry I put them in the oven at 200F for 1 hr cardboard and all, open the door and let them cool and the paint is hard as a rock.
Different strokes... The inserts only cost a few dollars, and I have never had a 'touch up' problem. Also, I don't think VHT comes in B5 Blue or F8 green.How is that better?? cost more $$ you can get an old electric oven for free put it in your garage or a shed like me guest in case of an explosion, witch I have never had. VHT works great but you have to bake it to make it work. I think everyone should have a oven in there garage,
just my opinion.
Wow, never heard of plastic sockets.Use plastic sockets....
Just a point. I believe you meant flank drive.Keeping build up to a minimum helps. I like using a quality flange drive socket.
just my opinion.
Baking chemical paints inside your garage a good idea? I live in the city and something that intrusive inside my garage or in my shed for the three or four times I might use it a year at best? I think that's for somebody that has a big shop in a lot of room, BUT ABSOLUTELY PUT IT OUT IN THE SHED OR OUTSIDE WHERE NO ONE'S GOING TO BE HUFFING THE FUMES OFF THE COOKING PAINT!How is that better?? cost more $$ you can get an old electric oven for free put it in your garage or a shed like me guest in case of an explosion, witch I have never had. VHT works great but you have to bake it to make it work. I think everyone should have a oven in there garage,
just my opinion.
