Newbomb Turk
As the rocker shaft moves up it gets closer to the valve tip
Look at the centerlines of the valve and the shaft stands
F’ing treed lol.
Turk, post #47.
The sweep width on the valve tip is also dependent on the valve travel [ lift ]. I mentioned that in post #46. More lift, wider sweep width. If you claim otherwise, you have stumbled onto the eighth wonder of the world....
No, not wrong, but right again. I am amazed at how dumb/ignorant you are over high school geometry. I will be back later with some drawings/diagrams to prove the point.
I don't have to look at the B3 website to know how geometry works. The error I pointed out a couple of years back is still there...has not been corrected. I cannot get that websire to work, but from memory, it stated that the rocker ratio never changes. It does. P'rod length can change the ratio, the ratio being valve lift divided by lobe lift. Here is just one example:
Most experts agree that the narrowest sweep on the valve tip is obtained when the rocker tip is centered on the valve tip at mid-valve lift...with the c/line of the rocker at 90* to the valve stem at mid lift. The drawings below are based on that. I have purposely exaggerated the sizeto make it easier to understand. The rocker tip moves through an arc, based on the radius of the centre of the rocker pivot to the rocker tip. A small rocker like the SBM, swings through a tighter arc & gives a wider sweep pattern on the valve tip [ for the same valve lift ] that a longer rocker would give.
You will see from the NONSENSE of n/bomb Turk in post #54 that he thinks somehow a 1" valve lift can have a narrow sweep pattern. 100% wrong. And he thinks geometry can 'fix' it!! Nope, not when you are ALREADY using the mid-lift method above, which provides the narrowest sweep pattern.
And a hand drawing with no reference to the pivot location. Got it. You are wrong.
The pivot location would move depending on rocker length.
Seems like simple arc and radius geometry really.
A straight line from points a to b and then measure from that line to the arc, that’s sweep on the valve stem.
That’s how a longer rocker affects the pattern. Moving the pivot location like b3 does is dealing with variables that Bewy mentioned like getting the rocker arm centered or at a right angle at mid lift.
Turk,
You are heading for the World Record of getting it WRONG.
Firstly, nothing to do with DV. See if you can find anything in his writings/books like post #61.
If you cannot understand the simple premise that more valve lift will give a wider sweep, then you should stop building engines & only a fool would buy one from you.
Cookietruck understands my post because that part of it is simple geometry.
I have already provided drawings showing the concept. Although I did not provide actual measurements, anybody with half a brain could see the trend when [a] you change rocker length you change in rocker travel [ valve lift ]. It also makes no difference whether the rockers are shaft mounted or stud mounted because both types rotate around a fixed pivot point [ fulcrum ].
.040 is good, but .030 is bettertarget sweep width.
Based on a Hughes 1.6 rocker with a shaft center to roller center distance of 1.358", the minimum possible sweep with perfect geometry would be 0.034".
Just an observation, your "roller" is almost .6 in dia, is it supposed to be .3? That will change things a bit.
Even if it’s off a bit, your .080 wide sweep is about 100% wider than it should be.
That’s a ton. I hope you read (or have already read) the tech articles on the B3 website I linked above.
Since the mid 1980’s it’s been a fight to get Chrysler guys to stop living with horrible geometry.
Back then, the only fix was to mill the stands and use blocks like W series heads.
Mike has made it easy and affordable to fix these issues.
There is no excuse for guys (not you specifically but people in general) to not fix this.
There is even less for guys who refuse to understand geometry and to post incorrect **** and then defend it to the death.
