Hydraulic clutch set up issue
i undertstand the concept of how a cable works,, just your pic dont make any sense to me,,,i see it bolted to the exhaust not to a shifting fork,,and cant tell from the under dash pics where its all hooked up too,,, but if it works,,,must be ok and just cant tell from the pics,,,
does look a mess lol! the end of the cable inner is mounted/fixed to a bracket mounted via an exhaust clamp which is on the same "plane" or "tangent" of clutch fork travel.........the other end of the cable is mounted/fixed to a bracket just past the top of the clutch pedal,again on same path..........the cable OUTER sheath is connected to a bracket that is bolted to the clutch pedal,the other end of the cable outer "butts " up against the clutch fork,now when the pedal is activated the OUTER cable moves along the INNER cable route and "pushes" the clutch fork...........yup i know, its mad.........it works:cheers:
