pettybludart
Keith,it will be agood feeling knowing you have alot of newer parts,kinda takes the edge off while racing with the 4 speed!Good Luck at the track!I say low 13,s!
Fingers are crossed and hoping to hear everything will go good.:cheers:Well, drive shaft was tweaked a little and they fixed that, installed new bolts and straps and the vibration seems to be gone, also had Mike fix and reinforce the snubber. On my way to the track for some 1/4 mile action, hopefully it holds up and doesn't break, maybe even get a good time running the drag radials!!
So, wish me luck, cross your fingers, or say a prayer for me and my car!! :cheers:
:cheers::cheers: SOunds good Keith!! Glad to hear it made the trip without any more breaks. Why won't the tach read? Do you need the tach adapter?
I have a vintage Sun tach from the 1960's, just won't read at high rpm's, it actually the needle goes the oppisite way the higher you rev it, works well at low rpms. Mike has the same tach and MSD, his does the same thing too. I was told MSD may have a filter that will allow the tach to work, otherwise I need to have the tach or circits rebuilt or updated and it will work.
Mikes Coronet ran awesome, his best time in it was a 13.0 on bald street radials, I am sure he will chime in with his times. I also met a young guy with a 67-68 Valiant 2 door sedan that he bought a couple days ago, very clean rust free 60,000 mile car. I told him about FABO, he said he will check it out today!!! Also met a guy running a 70 Dart with a 416 and a 4-speed, his first time racing it and he was running 12.80's easy, had lots of wheel spin.
