bobscuda67
Last year I had a flare up problem on my rebuilt 904. Flared up bad between 1/2-2/3 gear changes. Adjusted the throttle rod back and forth, cranked up the pressure relief valve, adjusted the bands. Still did it. Took it out and it had a burned up kickdown band, after 20 miles of driving. It had a Trans Go SC-TF kit when I bought it, so I called them for advise. The tech told me I needed a TF-2 kit since I went from 273 to a 340 engine.
Over the winter I installed the TF-2 kit and a new A500 kickdown band. I also installed Alto Red Eagle clutches and Kolene steels with an extra one in the foreward and the direct drum. Set the foreward clutch pack at .025 and the direct at .073. Set the pressure relief valve to the TF-2 lowest setting. Put it together and air tested it. All was well.
Installed it this spring and it still flares between gear changes, but not as bad as before. Adjusted the throttle pressure rod back and forth, still flares but shift points do change. The harder I get on it the bigger the flare.
When it was rebuilt before I had the 2;74 gear set installed and a newer input shaft. I wonder if the pump should have been changed or if there is a mismatch of hard parts causing a pressure leak. I guess the next step would be to test the servo and line pressure.
How would I do a pressure test and what should the readings be.
This thing has me pulling my hair out. Thank's guys for any help.
