CudaFactHackJob
Before you pull the pump, pull in and out on the input shaft to see how much endplay it has.
Thanks, will do.Before you pull the pump, pull in and out on the input shaft to see how much endplay it has.
I checked the input shaft yesterday, I've got maybe 1/16" play in and out. Compared with another core 727 I have in the shop that has probably 1/2" or more!Before you pull the pump, pull in and out on the input shaft to see how much endplay it has.
Why not?the direct clutches aren't worth installing...
Ahh, thanks. That makes sense. I remember he mentioned Eagle bands and clutches I think, just didn't realize he was talking about the brand when he said they weren't worth installing.He recommends Alto Red Eagle (the best) clutches in just about every single transmission thread he talk in. It's probably in here somewhere.
Does anyone have any ideas as to why the front servo spring is missing? Is this a common modification or did someone make a boo-boo?
Thanks a bunch. I was studying my 727 book last night and learned that I misspoke. I'm off to work, but I'll check out those threads later today.That's the accumulator. Everyone has their preference on whether to leave the spring, ditch it, install a blocker rod/spacer, and combinations of all of those. I think there was just a thread on it a few weeks ago. You may want to try to find it. I'll try as well.
I think I'll try the Red Eagles and try what you do with the clutches, but I have a couple questions.I always run a spring, but I stick a 1/2-5/8" long piece of 1/2" ID iron water pipe inside the spring. I like the .061 Red eagles so I can install an extra one in the direct pack; oems for the forward clutch. I've been putting five in every direct pack anymore. Five thins fit into the four plate drum with the stock top plate, but I use the lower forward ridged plate on top in the three plate drum to install five.
Thanks a lot, that makes good sense now. I remember when I had the clutches replaced in my 904, the guy said he removed the waved ring altogether for crisper shifts. He was right, but it also had a pretty harsh reverse engagement. So maybe he didn't replace it with a flat retaining ring?The only time I have to buy the extra ridged plate is if I have a 3 plate direct. Then I need it for the additional clearance so I can run five .061 Red Eagles in there. But if you already have a four plate, the five thins will fit with the stock top plate. If you are running a stall converter, you can put a flat retaining ring (they are selective) in the direct drum without encountering a harsh reverse engagement. The waved ring can be inserted into the groove with the ridged plate but it takes some twisting back and forth and you might not end up with enough clutch clearance. The soft 1-2 was probably something else. But I'm not absolutely positive. Was your kickdown set right? Sounds like you don't have one hooked up at all. Let's see what was done to your valve body. But I would def put in a spring; along with a stubby section of 1/2" ID iron water pipe (the OD fits the inside of the spring very well) 1/2 to 5/8" long.
