Fluid is red and crystal clear, doesn't smell burnt at all.
Thanks, me too! Big thanks to @CudaFactHackJob and everyone else who chimed in. I didn’t grow up working on cars, so every “little” thing I learn is huge to me.Glad you got her sorted out!
Be well,
Pat
Thanks, I know I should’ve made sure it was adjusted correctly already, but I’ll go back and make double sure. I also suspect the kickdown linkage isn’t correct for my car. I had quite a time finding what I think is the correct linkage, so I’m going to get that installed.Adjusting your "Kickdown" should affect your shifting points and sharpness.
Just a thought before removing the transmission. Remove the out put line from the cooler and see if you get a good flow. Maybe you have a restriction somewhere in that area. Sounds like somewhere you may have a plug.It’s possible, but considering how diligent I was being with monitoring the level, I’d say not likely.
I should have it out within a day or two, then I’ll post pictures of the snout. I’m curious to see what the seal and bushing look like as well.
Engine on for just a moment and in neutral, brakes on. Transmission needs to be working. Place line or attached hose in a bucket so not to make a mess. A helper starting and shutting down the motor may help. Did not no you needed details. BE SAFE!!!! Hope this is your issue.Can/should I do this with the engine off?
Like I always say. New don't mean good. lolTrudat...sometimes NEW stuff doesn't even work like it's supposed to..
Tell me something I don't know! But seriously the way I see it, I could look at it two ways: I could get frustrated and piss and moan about it, or I could see this as an opportunity.That's "good news"?!? You, sir, have a sick mind!
