68 Dart trunk lid, good condition... $75.00. Dodge Dart doors... $100.00 for left door, 80.00 for right door, right door has a small amount of rust, left is near perfect. 67 to 72 V-8 A-Body K-member, have the motor mount brackets for 318 one set, and one set for 340-360..$100.00. Also have torsion bars for $40.00. 1971 904 318 A-Body transmission used, worked when pulled...$100.00. Have a set of 71 Dart hub caps...20.00. 73 Dodge Dart V-8 radiator, used original...40.00. 71 Dart front valance...$20.00. 71 Dart V-8 engine wire harness...$20.00. 69 Dart V-8 engine wire harness 20.00. A-body 67-76 rear shackles with bushings, new $40.00. 360 car oil pan w/pickup tube...25.00
So I was following this car since last month when it posted in an earlier ad and posted some questions about it in another thread. This could be a deal for someone closer.
There are some questions about the claims that seem irregular (270 engine, 391 rear).
I used to live in the area, and would probably try to make a deal on it if still there, but shipping makes it a no deal for me. Could be a very cool project. Then again, it could be another money pit.
No pics, but a 66 Dart /6 near Albany NY posted to CL for $900. Thought some may find it interesting as I thought there were a number of parts that are 66 1 year only... Dodge Dart 1966
Just reassembled by Nickens. New Callies Magnum XL crankshaft 4.625 stroke. New Callies Ultra I beam rods BBC 7.1. New Diamond 4.515, 10.75/1 pistons. Crankshaft and pistons were lightened to rpm. This repaired short block (window repair) has been 9.20's in a 3600 lb car on pump gas with a roller cam with 9.75:1 compression. Terry Haddock of Lone Star Block repair, repairs the window. I have $13,700.00 in this shortblock. These are badass high dollar parts. After all it is a hemi. I only talk on the phone and can smell a scammer from miles away. Sent me you phone number and I will call you. I report all scammers to the authorities! This is a water block!
