zigs
Had this happen to mine. Had it at aguys shop that had no heat . I asked him to drain the block out ,He said he did. I got it home and several months went buy, I had not checked the engine ( I was working on other things at the time)desided to put fluids back in and as I was filling the radiator I could hear something running on the floor. Yup! all the frost plugs had blown. Had to pull the engine to replace them. Got the engine running ,ran for about an hour off and on ,took it for a spin , comming back home noticed steam from under the hood. Opened the hood and noticed brown goo. Not good. Needless to say pulled heads and had them magged. I had a cracked head, had to be welded and redecked. $1000 mistake for someones neglect and stupidity. I have tried getting ahold of the guy but I think he skipped. So your not alone. It just pisses ya off when you miss the small stuff.
