Daniel Garcia
Member
I have not, I have considered using a crown vic or an 83+ S10 regular cab frame thoughHave you considered going full Redneck and just putting the body on a Trail duster frame
You know, if you are hellbent on seeing this through, putting a duster body on the frame of a diesel vehicle would be the safer way to do itI have not, I have considered using a crown vic or an 83+ S10 regular cab frame though
This isn't a bad idea, AND it would be a hell of a lot less work, find a diesal 94ish reg cab Ram truck preferably 2wdr, shorten the frame as needed and everything power train wise bolts right up, fit the body and voila! You have essentially what you want for a reasonable investment. Worth a thinkYou know, if you are hellbent on seeing this through, putting a duster body on the frame of a diesel vehicle would be the safer way to do it
Saftey isn't cool thoughYou know, if you are hellbent on seeing this through, putting a duster body on the frame of a diesel vehicle would be the safer way to do it
