what do the heads flow? cam specs? carb size etc.? give us the low down----bobI have a set of Indy ez heads on my 526 and they flowed very well for just being "de buggered" as my engine builder says and on the 526 with 10.1 to 1 compression 2 1/8 stahl fenderwells and a SV-1 carb she made 734 hp and 702 tq
Posted via Topify using iPhone/iPad
On the next go around it will be less with different (dished) pistons to be pump swill (we have 93 here) compatible. Want as much cam as the heads will allow to be run on the street on swill.
This will probably be the end state motor for the KOS Demon. It is going in right now with the 13.9 build, but that C-16 $$$$$.
The B1 heads are by far the best mopar wedge heads made. And you don't have to deal with the *** holes at INDY CYLINDER SERVICE. 800 + LIFT 800 PLUS hP AND THEY ARE NOT OPENED UP YET!!!
I'm so interested in trying the EZ heads on the 500 with the Edelbrock Super Victor like you have there. With the Edelbrock Victor heads and the Indy 3X it made 928 HP. Maybe I should put the Victor heads back together and try back to back runs doing the swap.
