Sirsmiley9
When you install a one wire alternator from what I understand you run one wire straight to the battery, but I just wanted to confirm and ask what you connect the old alternator to voltage regulator wiring too
Simply said, I had 2 field wires on the new harness, green and blue. Connected (green) to the single field tab on the alternator.
I just left the other one disconnected, and it has been charging properly for 2 years now.
Yes.
I confused the issue.
You need to describe exactly what alternator you have. Whatever you know about it - Is it a Chrysler? Who you bought it from? Or a photo?I believe it is a one wire to the battery, but I didn’t realize there was an addition wire to a ground, but does anyone know what you are supposed to do with the old wiring to the alternator and voltage regulator. I remember seeing something about unplugging them awhile ago, but I closed the tab
have been on millions of cars. .
I would dispute that. My impression is that they are mostly found on industrial and some trucks. Ford/GM/Chrysler certainly did not use them, or not much. The "usual" Toyota/ Denso alternator is not "one wire."
Again, for me one big downer is that they require a HUGE oversize charge wire to properly provide well regulated voltage at the battery end. This is even more critical in a trunk mount situation. Frankly, I see NO ADVANTAGE at all to a "one wire" vs any setup with a separate "sense" wire which adds "voltage accuracy" to the installation.
I do see the attraction (simplicity) and in fact have one on my old (6v-12V) Farmall.
As I recall GM had alternators with built in regulators for about 30 years from the 80s to 2000s
Yes GM introduced the internally regulated SI alternating current 'Generators' to replace the externally regulated DN models.As I recall GM had alternators with built in regulators for about 30 years from the 80s to 2000s
OK. So the next questions are why? Usually people choose one of these for a particular reason or someone told them is was a good idea. If you are in the latter catagory, my recommendation is to exchange or return it.Sorry for not mentioning the type of alternator its a 75 amp powermaster chrysler square back One wire internally regulated alternator.
I think the term shunt in the instructions is misleading.
Basically what you are doing is bypassing the ammeter.
You still need all the existing OEM wiring hooked up as it was originally. (Except the voltage regulator and field related wires)
The benefit to doing this is now the loads of the car (main splice, etc) are shared by two spade connectors thru the bulkhead connector vs just 1.
In my opinion yes.But is it still good to run the original black 10ga wire to the ALT output stud as well?
