Dave999
yeah just replaced gasket on my hemi 6, uses the same set up more or less, no brass washer in the middle but all else much the same.
even with a blown out gasket at the exhaust header of no.5 and no. 6 those nuts were still on and were reassuringly tight.
caused my own pain here by re-using the gasket 2 years ago.... new gasket now...
being cheap and of course then i had to do the job twice.......
having a selection of 1/2 inch or 13mm sockets a set of fat and thin extensions a decent ratchet with a good "click" resolution, the more clicks the better, and a magnetic pickup wand makes this job easier.
and on my RHD car its also time to take out the heater/fan motor and lube its bushes and replace its brushes..... not a problem on yours. i just can't do it with the inlet in place
but if you had clutch z bar, starter motor, brake pipes, or steering stuff to do, now would be the time when you have an excess of space available from above
Dave
Dave
