is it legal?
Cut them out? Angle grinder with a cut off wheel should make short work of them. Just need to take a look and see how they are mounted. If there held in with a few spot welds just drill them out.
Also scraping out the under coating from inside the doors will shave some weight too. As Will cutting sections out of the inner door panel or at least drilling some holes in it.
wow there was some big triple girders inside the doors. took 52 pounds off to each door!
Plexiglass Uggggg !
Removing support Beams Ugggggg !
Just put a 150 shot on it !!!
Another $450 for the nitrous kit - uggg!
Probably another $2-300 to fill and get all the other
small stuff to work - ugggg!
a fire proof jacket required when using nitrous $$$$!!!! - uuugggggg!!!!
so much harder on the mechanical parts! Ugggg!
losing weight easier on mechanical parts and wallet!! yay!!!
dropped 1/2 second with FREE weight loss yaaayyyy!!!!
