moper
I agree with you I was making a quick point but if you took same weight cars that turn the same E.T.s if you Dyno and figured out there torque to the ground numbers I bet they would be similar through out the run.
That's the thing - if you take the same weight, and accelerate it to the same mph over the same distance, you have effectively averaged everything into one number. ET is not the the number that really means much besides bragging rights. MPH is. That's because most savvy racers know ETs can be fiddled with easilly, and especially in class racing - they are. This is an observation and not meant as a cheap shot - I think you've generalized to the point that the numbers are the same because you want them to be.
Help me through this example - Let's assume two 3200lbs cars that run 125mph in the quarter mile:
Car #1 has a N/A 500" engine with a 3spd trans.
Car #2 has a midly stroked slant six with a big single turbo and a power glide.
They both cros the stripe at the 125mph mark. Which is faster? Which has more horsepower? Most importanly - how can you tell given the info supplied?
"Then they were wrong. And I'm not bein a smartass......it's got something to do with the physics of it. I cannot explain it all. I just KNOW torque and HP always cross at 5252 RPM......"
The numbers will only cross "every time" theoretically and on the dyno simulation programs. That's because the horsepower numbers are crunched. And the inputs for that crunching are data points based on human being created correction factors. Not all dyno operators think the same way and so correction factors can vary (or be skewed), plus not all dynos run the same software, and not all software uses the same number of data points per second for their calculations. That means there's a very real chance of error in the result when compared to a theoretical "always". So while theoretically using a mathematical constant they "will always cross" at 5252, the dyno sheets many believe as empirical truth may not show that torque and horsepower relationship
