Is your 67-76 A-body windshield leaking ?
Oldmanmopar
Going left turning right
Danielsville Pa. 18038
Check here. You can reach it in the car without removing the windshield. Not easy but can be done by someone with little arms and Belly.
Watch the video
Deffinetly something to watch when removing glass .nice video!
Watch the video
Appreciate the video, but that hole area you are referring is in no way connected to the square hole cowl drain. Thats a completely separate piece spot welded on. packing it with dum dum does absolutely nothing for a leak.
Most of times glass shops fill drain holes with sealant which can prevent draining.
I need an explanation. Does the leaking really stop with dum dum pressed into the little bracket at the end of the straw shown in the video? Assuming no rust out in the trough. I've got a 67 Barracuda that leaks in the front windshield mainly on drivers side. Car has good rubberstrip. What does anyone say?
I was told to use this for leaking windshield gaskets. Doesn't harden. Put it in the gasket grooves before installing. Gets messy so have rags and wax and grease remover. Still haven't done it but did buy it.
This has been my observation as well......I will have to take a closer look before the windshield goes in.
