I would step right into a Trick Flow head.I suppose if I was racing a 340, yes it would be aluminum heads a single plane intake and a 750 Holley carb. That would be my starting "recipe"
Enough head OOTB to build a potent street strip deal.
and it's free adviceBecause I’m a nice guy, I’ll tell you EXACTLY why I said to start with the valve job.
Because thats where the most power is. Because it establishes the throat size. Because it is the biggest factor in how the rest of the port is shaped.
I’m all for working the guide but for the amount of time and effort spent the most power to be had is in the valve job. You’ll get very little in return working the guide boss (although I suggest you do do it, just not at first) compared to getting the valve job correct.
Keep the tail long, have some 1 pc bronze put in. Stick to a 3 angle vj, no 15 top.Just getting started on a set of 1972 j's, milled the guide down .200 and about to profile the guide. was there a long thread about porting j/x heads? I can't seem to find it. anyway, can the guide tail be removed completely? This will be going on a somewhat stock appearing 6 pack, intake has been deep port matched. I know aluminum heads would be much better but the 6 pack intake don't flow all the great anyway, plus the looks on their faces when they see they got smacked by a SB with stock heads is fun.
Thanks for the help. I’d like to work on one port int & exh and have it flowed to see if it’s worth my time. Not sure if I should have it flowed with the stock 1.88 valve and see if I’m on the right track or have it ruff cut for 2.02 and blend it in a bit and flow it?Keep the tail long, have some 1 pc bronze put in. Stick to a 3 angle vj, no 15 top.
Blend all around the intake valve in the chamber, a little into the chamber on straight shot, open pinch to max .050 thick or a hair less. Work the roof a ton and smooth n ramp it down keep the throat on the small side till the vj is done, make the bowl almost a bell, do not over work the straigh/common side ssr...and almost leave the dogleg side of ssr tall as you can. Work on cross section but keep rounded/bullnosed. Common wall straighten to head bolt but dont make it flat all the way into the bowl, let it still kick out..so that there IS still a bowl on that side. You want to feel sharp angles at seat but also radius that throat from them. Dont make a bucket out of it.
Only knock some of the wall to floor hump down, for area at the ssr
You make it sound so easy.Keep the tail long, have some 1 pc bronze put in. Stick to a 3 angle vj, no 15 top.
If you're going to do it... do not use a 1.88 tulip stocker. What you will end up with are poor low mid and decent 'for the valve head diameter ' peakf flow.Thanks for the help. I’d like to work on one port int & exh and have it flowed to see if it’s worth my time. Not sure if I should have it flowed with the stock 1.88 valve and see if I’m on the right track or have it ruff cut for 2.02 and blend it in a bit and flow it?
Hi Pat, yes I will, but that area is usually the lowest on the list. Most of the flow gains on these heads as I understand it are guide, bowl, and chamber along with a good valve job. These are still at 1.88 so I’m going to ruff everything in then send to machine shop to cut 2.02 size, then finish bowl blend, then back to shop for finishing. I my flow a port to see where I stand
and what do those flow………….
Yes I’m interested in flo also.
Good stuff Mike. Looking forward to seeing your handy work. The beast shoild respond nicely to the added flow!Hi Pat, yes I will, but that area is usually the lowest on the list. Most of the flow gains on these heads as I understand it are guide, bowl, and chamber along with a good valve job. These are still at 1.88 so I’m going to ruff everything in then send to machine shop to cut 2.02 size, then finish bowl blend, then back to shop for finishing. I my flow a port to see where I stand
