d55dave
Perfect, keep us posted! I also use a little thread sealer on the band stud that protrudes through the case, and a very light skim of silicone on the underside of the jam nut.
Good tip!Perfect, keep us posted! I also use a little thread sealer on the band stud that protrudes through the case, and a very light skim of silicone on the underside of the jam nut.
Woohoo....it drives!
Back on the ground
Ok....one issue right off the bat...
When I take off in drive, it starts in second gear, but I can manually put it in first and manually go through the gears.
Could it be the throttle pressure?
Any ideas?
Jeff
Hmmmm...I do have a little trouble getting it into park.....but once it's in drive, it starts in second gear. ..?nice car.
i think shift linkage adjustment.
That's 2 votes for linkage. ...I'll definitely check it out!Sounds like the gear selector is off a notch...
double check your linkage...
Thanks guys!
Jeff
I don't want to shift. ...that's why I have an automatic!Go with manual valve body
Linkage problem solved...
Everything seemed correct to me.....How did the air pressure test check out before you mounted the valve body Jeff? If all was ok I would suggest as others have that the shifter linkage is a tad out or you have a cross leak somewhere in the valve body. also the 1-2 shift valve might have stuck in the 2nd gear position. With the 1-2 shift valve at rest against spring pressure it is hydraulically impossible that 2nd gear can be engaged even with the shifter in manual 2nd.
I guess I'll try adjusting the linkage....but that doesn't make sense to me...
If I shift into drive, it should start in first regardless of my linkage?
The only way I get first gear is if I manually shift it to first.....
Could out of adjustment linkage cause that???
Jeff
OK.....thanks guys.....can't wait to get out there and mess with it....
Jeff
How do you find the neutral spot on the trans/rooster comb? All I know for sure is park...Old and lazy is no way to go through life!!!! LOL
Good job Jeff.
Agree in linkage. I always place the shifter in N and find N notch on trans arm. All the way back on trans arm is park.
Two clicks forward on the arm
Park is back, R is next, N is second click
