Aussiemopars
Hey Dude... didn't someone tell ya... it's Superbowl Sunday... even I know that and I'm on the other side of the world... where's your head at?? I'm sure we can give ya a break for a day...
Lol...no Superbowl or any NFL for me....Hey Dude... didn't someone tell ya... it's Superbowl Sunday... even I know that and I'm on the other side of the world... where's your head at?? I'm sure we can give ya a break for a day...
We finished our rebuild up just now. Lol.
Grinding the 1-2 kickdown valve/piston thing was the most tedious part. Lol. We don't have the most precise machining equipment. But it should work.
And adjusting the internal kickdown lever on the valvebody was difficult to find clear directions for on the internet. Finally found the .625 spec and used the dial indicator to set the depth in that.
Clutch clearances for both drums (4 disk for both) came out to .048-.052. Out kit had waffles and smooths.
Overall it went really well, and was a pretty simple unit.
I appreciate all the help and knowledge in this thread, and I hope I didn't muddy jeffs thread up to much. Lol
Thanks again. Eric
Now...installation and testing?!!!!!!
Jeff
Can you tell me more about that internal band adjustment and measurement?No, not quite yet. We're doing a full resto that we're about half way through. Lol.
Next weekend we can get back to work on engine assembly and finish that up.
Than we are moving to the rear axle and suspension. Moving the springs in with offset shackles and attempting to shove a 275/60/15 under it.
Eric
Jeff
I think you can adjust it by dropping the pan and removing the valve body.....I'm getting real bad slip from 1st to 2nd now and I'm wondering if I can adjust it by dropping the pan or is it a tranny out job?? ....waiting to see if yours needs adjustment and what you need to do.
OK.....thanks! All in the TransGo instructions.....We just adjusted both bands per transgo specs.
The other adjustment was for the kickdown "cam" to plunger depth.
You fully depress kickdown plunger into the valve body, (which pretty much puts it flush with the valve body), and measure .625 to the cam. Adjust with philips head screw and lick nut.
Jeff
Can't wait to be at that stage! Still doing bushings.....!Yeah. Sorry. My buddy adjusted the bands while I was working on other stuff. But he said it went well. And according to transgo specs. Wish I was more help on that one. Lol
Did you replace all your bushing or just some?
Jeff
All of our bushings were in beautiful shape. So we ended up not replacing any bushings. Other than some Burnt clutches the tranny was in beautiful shape internally. We pulled ours apart mostly because it was an unknown transmission and for preventative maintenance and upgrades.
LOL.....seem to be an epidemic !
I call it wavy gravy. LOL. Far out man. LOL.
And the word mumbly peg still makes me giggle.
Jeff if you don't mind I'll answer the other guys question about the band adjustment.
@Aussiemopars The front band is the second gear band and the adjustment is on the outside of the case. Also check your throttle pressure linkage adjustment as it will cause slippage issues if not adjusted right
I'm not at that point yet.....but when I get there, I sure will!Great Jeff, let us know how you did it. Pics please.
