stumblinhorse
@MOPEkidD-3 who did your heads? My J's arrive today and am on the fence for leaving them alone or taking them somewhere for some work.
Good job on the carnage!!! What was the boost and afr when this let go?Let's see the flow sheet.
Turbo on a stock bottom is only a matter of time. Have fun while it lasts.
Get it too lean and those cast factory hypers will go bye bye...and shower the inside of that motor once they get flung by the crank and blown into the intake port and other cylinders.
I'd do it on a 4 hole plate but would pause on the Magnum 6 hole plate.Are you going to drill holes in between the holes on your oil filter adapter plate?
Don't think I have ever seen a set of rod bearings so uniformly worn with the copper showing the same on all 8. Would make me wonder if the rods are distorting when the nuts are torqued.
And the offset is different from what I recently found.Also I noticed taking off that factory plate it's definitely thicker steel than the LA ones. The moment I popped it loose I thought "I probably could have left that on there and it would have worked perfectly" LOL
And on the rod bearings, that was just an observation.... your explanations are probably spot on. If the crank is not scored a lot or deeply, then A-OK.
There is the Mr Gasket 1121G at .028" thick. Not sure how it will hold under boost.... some have noted them not holding as well.... I dunno all the circumstances in their application in those cases however, like: were the decks and head surfaces true, and were the head bolts re-torqued after a few heat cycles?
I've used similar composition gaskets to the 1121G's in my 2.6L Mitsu with 14-15 psi boost for rally use and not had any issues ever...... I take that back: 1 did fail once in a rally, but the head had warped a bit.
Putting a thin coat of KopperKote on would not be a bad idea IHMO.
