K.O. SWINGER
Meeting in the alley since 1976
The 284 hydraulic was actually one of the best old 340 cams when used with 10 to 1 or more compression. the cam is only as good as the rest of the parts supporting it as mentioned! It can be ran into the 12s in a 3200 lb car successfully if you're needing to go faster than that it's probably time to step up to a solid.
