TylerW
Hey everyone:
I'm having a big problem getting my throttle pressure rod adjusted correctly. I've searched thoroughly and haven't really seen a solution.
My vehicle is a '71 Plymouth that I put together from several donor vehicles. Engine is a 1973 318 w/2280 Holley carb.
Trans is a '67 A904. I am using the throttle pressure linkage from a 1975 Plymouth Duster. Everything fits, but the throttle rod can't give enough "push" at the trans..meaning if the carb is at WOT, the trans arm isn't.
If I try to adjust it as the Chrysler manual suggests, loosening the slider at the trans and pushing it forward, the linkage will not let the carb go to WOT.
I did find a bar(at the carb) that's threaded and adjustable but that still isn't solving it.
So what's up here...gonna have to find an earlier model throttle pressure linkage or something?
Thanks guys.
Thanks guys.
