[FOR SALE] kelsey hayes brakes FS/FT
packers6947
colorado springs
Rating - 0%
0   0   0
Small bolt circle
replaced all bearings
slotted and drilled rotors
brand new pads
core calipers
upper control arms
should be all you need to have disks
looking to get 450.00 free shipping in u.s.
located in colorado 80917
looking for in trade
8 3/4 a-body reared
late model hemi build able
front floors for a-body
340 block and crank
1968 finders good shape
let me know what you got
thanks in advance joe
Going to need more than that to switch to discs.... PM me if you want to deal on rotors assemblies only...
M/C... hold off valve for rears .. new calipers... caliper brake lines ... caliper bolts ... lower ball joints .... minimum +350 dollars worth ...
just looks like rotors with hubs no spindles. upper arms are the same for small bolt drums to disc conversion. just my .02
Yes .... most important part missing spindles .... 450.... UUHHHH NO...
Are you sure the spindles are missing? It sure looks like the dust shields are in the picture and are perfectly spaced. That would happen if the if the dust shields was attached to the spindles and the ball joints were removed. When the op shows up again we will get all the details.
spindles are there, how else would all the bearing be there
also have caliper bolts
can give you old ball joints if you want them but i think trash
also has brand new pads in the box and used pads if you want them as well i will get more pictures
thanks in advance
joe
I think you and alot of people have missed this at the bottom
Commentary is NOT allowed in For Sale forums. Relevant questions ONLY!
in otherwords if you have questions don't flame a seller; PM them
Just curious.... did you mount the calipers to the spindle with the new rotors... the reason i ask... i received the rotors with the parts i bought from a guy on this site and the caliper contacts the rotor center hub outer circumference when mounted ... so i ordered another rotor on my own and same results ......
Need new thread.
if i still have trouble with the on i am about to get???? If i have to go to Wagner rotors .... does anybody know where to get these Wagner rotors ?
found the brake cable brackets, brake caliper bolts and lower ball joints but could not find the bolts for the lower ball joint.
