A follow-up to my last post, #25 (above). I did order and receive the rotors from Rock Auto. I received machined hats even though cast hats are shown in the listing on RA. These have the same problem, the diameter is too large and rub on the caliper seals. I have a large measuring caliper, 8", I bought from Amazon, its quite helpful for measuring these:
Amazon.com
Based on my measurements, the hat diameter is about .1300" too large, so at least at least .0650"or more would have to be taken off the hat, a bit more would probably be better, the set I recently cut down an a lathe I took off about .0800". I did notice these on RA
I'm getting tired of returning brake rotors, so if someone tries these, let us know if they fit without rubbing the seals.
Amazon.com
