mopar340dave
Well, I've got my 69 swinger sitting here with factory kh disc....what would you offer for the spindles, rotors and calipers?
abs just came out with a 4" patern conversion kit, they are available from classic industries. i just put their kit on a couple of vehicles at the shop, easy breasy.
All v8 a-bodys 1973 and later had big bolt pattern. I think that is why it is listed that way. Should work on yours but should check with them.I'm a bit confused. The classic industries site says that it will only fit 68-72 model years. Mine is a 1974. What am I missing here. What was so different AFTER 1972???
If it were mine, I would sell the small bolt pattern craigers and upgrade to the larger pattern, parts are cheaper and no need to frabracate anything.
So is every 6 cylinder car a 9" front drum brake car. and i need a kit with spindles to replace it all.
there is really no way to upgrade my car to disc brakes AND retain the 4 inch bolt pattern. Just goes to show that an impatient novice will make very costly mistakes! I have just purchased new Cragar SS wheels and tires that would be useless if I upgrade.
Mine is a slant six. I guess /6 cars came standard with drums and optioned for discs? I looked at the ABS site and will phone them tomorrow. Seems reasonable--especially if I leave it a /6. I'm learning, but I'm slow.
From 1973 up /6 standard brakes were 4 wheel drum, discs were optional but required with sure grip diff option. V8 standard brakes were front discs.
All 73-76 front disc brake equipped A bodies were large bolt pattern.
All 73-76 front drum brake equipped A bodies were small bolt pattern.
i have researched this over and over again.... and asper members on this board ... IF you want to retain small bolt pattern .... you are better off buying from SSBC ... the ONLY concern i have and not purchased the kit yet .... is if after installing this kit .. will the factory steelies clear the calipers on SSBC kit .. i have been told NO .... BUT rallies ( road wheels ) will clear the SSBC caliper ...
Used the ssbc disc brake kit on my Barracuda. It was a very easy bolt on installation. The kit is expensive, but it has pretty much everything you need. That includes a dual reservoir master cylinder and proportioning valve. The rotors are drilled for both the 4" and 4 1/2" bolt patterns and both the 7/16" and 1/2" studs are included. If you start out with the small bolt pattern, you can upgrade to the larger one later.
I had 15" Cragars on my Barracuda without any problems. I can't say for sure about 14"I just bought a 64 barracuda with 9" drums. I was wondering if you had any issues installing the brake kit. I'm using crager sst rims that are 14x6.
Thanks
Carmen
