Captainkirk
Old School Mopar Warrior
Sounds like a plan, John.I decided to slowly build an engine. I’m waiting on a shipping quote for a (Hasn’t been run since machined) bored .40 over LA360 from ‘75 with 974 heads and original crank. All in excellent condition, the block is ready to get a couple final cleanings and for the bottom end assembly. Hopefully the shipping doesn’t kill me and I go ahead with the purchase. This is the same combo I have in my car, other than my current block is a 4006830-360-9 and his a 360-2. It won’t let me download the pictures of the block for some reason. I’m going to start a build thread once I actually take possession of an engine... Hopefully it’s this one. I thought I had a line on a great deal for .40 over pistons, but it turned out to be around the actual retail cost and not a set I’d choose based on compression specs, but not a bad choice if my budget was shoe string(it’s not much more though. Lol). I would’ve started with a stock short block and been happy, but since this one will need pistons, I’m going to go a step up... Not by much, but a good step and money well spent, easily worth the extra $200 over the Sealed Power 405CP’s, which would’ve been an upgrade from stock compression at just under 9:1 with the .40 over, but I can get around 10:1 from Keith Black or Speed Pro, depending on which way I go on the build. I’m learning every day and looking forward to starting a build, now that I’ve decided on a direction. Thank you CaptsonKirk and the rest of you! Side note, randomness. I was was Shatners driver on a movie for a few days. I was driving the Electric 10ton tractor truck, but got pulled to drive him around for the few days he was shooting with us. He was hilarious and a stand up guy.
FWIW, I chose the Speed Pro forged 10:1 pistons (against many here's better judgement)...most felt the Keith Black Hypers are a better choice due to the weight...which I can't dispute; they are heavy sons-of-guns. I weighed one of them at 727 grams. BUT...I wanted forged pistons rather than hypers; the KBs have their shortcomings as well. I am well-impressed with the SP's. Coupled with the forged crank and the new Eagle forged rods, the bottom end oughta be solid as an ox and pretty much bulletproof. FWIW, while the SP's are heavier, the Eagle rods are lighter than the stock forged 340 rods. Every little bit helps...
Always thought Bill Shatner was a pretty cool dude...
EDIT: I had already had the block honed std a few years back. The only SP slugs I could get were + .030 so I had to have the block bored .030 over. Then I had to have the crank re-balanced because of the new rods. So it pays to plan well ahead or you'll end up doing things twice...
