LA Block/Magnum Heads
Many people have LA blocks...and the heads for most part are a performance gain over their existing head
I forget, but why is that a la cam won't work in a magnum engine? Oiled differently?
Cam needs to have oil holes in number 2 and 4 journals to provide oil up the cam bearing to rocker shafts..those cam journals could also be grooved...
You can put an LA cam in a magnum block, but why would you? There is no advantage to using a FTH cam in a hydraulic roller block, only disadvantage. The profile of a hydraulic roller is vastly superior to that of the flat tappet, no worries of rolling a lobe on roller cam, no worries of high zinc oil and they run cooler and have less friction. Stick with the roller!!!
