And you as well.Excellent selection there 73AbodEE
'Cocked & Loaded' {1989}
1963
More articles
Chrysler to introduce a new shorter-deck engine block to the 'A-Series'.
The 'Low-A' engine will be listed as the 'LA' series engine.
Sorry but have to call you on that one. Both the poly 318 and the 273/318 La's had 9.60" deck height. tmm Page 2
http://victorylibrary.com/mopar/deck-height.htm
April 1963
Popular Mechanics
Chrysler is introducing a new thin-wall casting engine block for the
upcoming Model Year. The engine will be designated the 'LA' engine.
This engine block is lighter than the current 'A' Block, which was introduced in 1956 by Chrysler, and called the 'Hy-Fire 277'.
The new designed thin-wall casting engine block will be 50 lbs. lighter than the
current 'A' engine block.
Don't mean to ruffle feathers.
Similarities Between Poly "A" engines and LA engines
Poly "A" blocks can be used with newer LA and Magnum heads.
Transmission bellhousing bolt pattern is the same.
Crankshafts interchange with 273/318 and internally balanced 340 LA engines.
Oil pump and distributor drive shafts are the same.
Oil pans from 273/318/340 LA engines will fit
Dampers from 273/318 and internally balanced 340 LA engines will fit.
Distributors from all LA engines will fit.
Poly timing chain and sprockets are the same as LA engines.
Poly block deck height, bore spacing and 59 degree lifter angle are the same as LA blocks.
1963
More 1963 articles from Popular Science
This is what 'Popular Science' wrote in their June 1963 upcoming
Chrysler new engine design.
I should have posted, that this was an incorrect statement from the Magazine, so the lesser knowing would know that this was a 'tongue-in-cheek' post.
I'm with ya Rusty. I wouldn't mind a early 60"s B Body with a hot teen. Here's a good stroker article from 2001.
http://www.hotrod.com/how-to/engine/mopp-0110-how-to-give-a-318-poly-engine-more-power/
Oh excuse us lesser knowing, almighty one. We know not what you know. It is an impossible mountain to climb.
Learn it, Live it, Love it.
Go Macon, Georgia,
