Here's the thing........if you go up much on the compression, you're gonna be fighting detonation with that small cam. Just one more thing to think about.
He’s wrongI guess that's their "high compression" piston. The Mabbco rep keeps telling me it will get at least 9:1 compression.
You quoted me but are speaking to the OP. I was merely pointing out what I found. I agree with you 100%.The piston "upgrade" is not an upgrade at all. There are two main pistons for the 360. Flat top and dished. The dished has a taller compression height and basically has the same compression. Although it sits higher in the bore at TDC, it has a dish, which reduces compression. The flat top has a shorter compression height and no dish. There are essentially different types of pistons that achieve basically the same thing. Different year model pistons. There WAS a 1971 only piston from Chrysler that was a flat top and near zero deck height that had an actual 9:1 compression for the 71 only model year, but those pistons are impossible to find in the aftermarket now. You DO NOT have a high compression piston, so stop digging for it. I don't understand your reasoning for returning the heads at all, as you've been told time and again that a low compression engine can be built to run and run strong. You're just not listening. It's your baby though, so have at it.
My bad. Sorry, I got precious little sleep last night.You quoted me but are speaking to the OP. I was merely pointing out what I found. I agree with you 100%.
...and thing is, they aren't REAL FAR off. He COULD see 9:1 with the .019" steel head gaskets and maybe a light mill.......he might not even need the mill. It would be close. I'd run it at what I figured which was 8.4. It'll run good. Probably better than good.He’s wrong
That would have my endorsement with more camshaft.If it was me I would be inclined to return the CNC heads and swap them for the regular 63cc speedmasters to gain some compression back. (Assuming they are in stock). They will flow good enough for what you are doing and give you a good bump in compression.
There’s no doubt that at 8.4 it could run good. And it’ll probably make ~300hp and most of us know what that’ll do in an abody. But early on he stated his goal of 400-450hp and he ain’t gettin there by just dropping on a set of OOTB heads and a mild cam....and thing is, they aren't REAL FAR off. He COULD see 9:1 with the .019" steel head gaskets and maybe a light mill.......he might not even need the mill. It would be close. I'd run it at what I figured which was 8.4. It'll run good. Probably better than good.
Nope.There’s no doubt that at 8.4 it could run good. And it’ll probably make ~300hp and most of us know what that’ll do in an abody. But early on he stated his goal of 400-450hp and he ain’t gettin there by just dropping on a set of OOTB heads and a mild cam.
@krazykuda , I’m originally from Oak Lawn. Small world.
There would have been no way I would have sent those heads back. Those were that engine's only chance at any decent power using those pistons, IMO. Flow trumps compression in "that" particular instance, IMO. But it's your deal, so carry on.
Me too! Went to OLCHS class of ‘87I was born in Oak Lawn... Christ Hospital...
Bought a set of KB107’s and a roller cam. Should be done by the middle of next week.So Matt,
Curious how you are making out with your 360 build.
Everything working out for you?
Yes, I had Alan P. (Pro stock racer) at Arc Race Engines do a complete rebuild. Hit just under 380 horses on the first pull on the dyno. Exactly what I wanted!Any updates on the build?
hey... not far from me.. I know where that's at actually...I went to Andrew High School in Tinley Park, class of '85...
