...........U could have the trans go-2 kit which has the shift command feature, so u would in fact have manual low.......the 5.0 lever has burned up many trannys.....it is for use with the rmvb........u need to have the proper clearances and settings.......u say that u have a "delay".........and that u have kd linkageshorten the rod alittle, see if that helps.........then adjust the front band to atleast 2 turns with the 5.0 lever, depending on what front servo u have, and forward pattern shift kit...w2hats ur receipt say for the tranny work.........kim........
