rapom65
Hey guys. Prior to ordering new push rods I have to correct a geometry issue with my roller rockers riding on the outer half (exhaust side) of the valve tips. The fix is to install lash caps. Having zero experience with these I'm in need of some advice.
The combo: Edelbrock RPM heads, 1.5 Crane Gold adjustable rockers. Valve stem dia. listed for these heads is .341.
The closest cap I've found is .342. Is this the correct cap to use with a .341 stem dia?
In order to move the roller contact point approx. 1/3 of the way across the valve tip what thickness of cap should I use? I've found .090, .080 and .060 cap thicknesses in the .342 size.
Thanks for the help.
