Demonic
They put a hole in the bottom of it and easy to do it's plastic
Fred, do you know the ABS plastic trick? This will work well if the wheelbarrow is a type of plastic that matches. You need a glass jar w a lid, some old Lego's or the plastic keys off a dead keyboard, and acetone. Put the key caps in the jar about halfway, about 1/4 full of acetone, and let it sit for 24 hrs with a good fitting lid. You'll have liquid plastic. It should be like a paste. If it's too thin add more key caps. too thick, add acetone. Wipe down the broken spot w acetone, mask the hole shut w tape and close the hole w the plastic paste. About a day later the acetone is evaporated and it is all better, strong as original.
This is for repairing Duster and Dart Sport grills, actually.
