Last one to post in this thread wins!
Well fellas a late start on the coast this morning, now back a few posts , because I’m cheep, I have fiberglass bumpers for the valiant , I’m gonna paint them gloss black , as well as the side marker lights and door handles , lock cyls, only because I m on a budget build and it’s just a driver ,part time racer , if at some point I could justify the cost I love Crome!
They do make a chrome wrap.
If it were anything,like a number matching car yes purest all the way , but it’s a driver .
I like when people do what they want with there car makes it interesting at car shows. Some I like and some not but it is your car and it will look good Biff.
Well just ordered new tranny lines from Summit the flexible ones so hope no more leaks.
Filled the radiator with antifreeze the other day and takes 3.5 gallons so I don't think I'll have an over heating problem. Deck lid is on the car and next week I hope to order windshield and rear glass gaskets. Gonna re tighten every nut and bolt on the car and try an align the front tires the best I can. tearing down the front bumper and cleaning it up so I can put that back on. I will have to have it re-chromed at some point but not in the check book now.
Should be on the road next month but not all done I plan on putting the interior in after I drive it around a bit so I can find all the rattles and do any adjusting on the doors and side glass.
Great idea Fred. Check the molding clips too Fred. No use installing the glass then the clips won't hold. HINT: if a clip won't hold the molding tight simply cut a piece of rubber and slide it in between the clip and the rubber gasket to put more pressure on it. If there is any doubt about the clip though replace it. The little bastards are cheap anymore. I know I have some in my bag of tricks but not enough for you to replace them all. Don't forget to seal the windshield/backglass as well because sure a **** it'll leak. You can get a tube of roofing tar and use a cartridge gun. Don't forget to shoot sealer between the body and the clip.
