Ok so where do we buy those ?
Somebody has too.See he probably loves it
Probably corners good !The wing is almost as big as the car. What a duffuss. Bet he built that himself. LOL
Probably have to get up to 100k before turning on the dome light or it may stallProbably corners good !
Gonna get new molding clips mine are good but like you said not worth it.Great idea Fred. Check the molding clips too Fred. No use installing the glass then the clips won't hold. HINT: if a clip won't hold the molding tight simply cut a piece of rubber and slide it in between the clip and the rubber gasket to put more pressure on it. If there is any doubt about the clip though replace it. The little bastards are cheap anymore. I know I have some in my bag of tricks but not enough for you to replace them all. Don't forget to seal the windshield/backglass as well because sure a **** it'll leak. You can get a tube of roofing tar and use a cartridge gun. Don't forget to shoot sealer between the body and the clip.
Is that a luggage rack or what?
Gotta get me one.
Those would be cool to have a made up.
Arrow da mic wing for turnsIs that a luggage rack or what?
LMAO...Arrow da mic wing for turns
Don't go overboard with the sealer Fred but a nice bead between the body and the rubber and then run your screwdriver over it to get any air bubbles out. Don't forget to shoot some sealer between the body and the clip as the water can go right past and create a water leak. Also run a small bead between the glass and the rubber before you lock it down.Gonna get new molding clips mine are good but like you said not worth it.
Good idea tar the **** out of it because I'm not wanting to do this twice.
Oh my!!! That would raise the dead
I see she's getting her gun off
I even gained weight I've always weighed around 135 and over 145 now.After being locked in for 6 weeks.
