diymirage
HP@idle > hondaHP@redline
You're also a gearheadI'm a small guy but I do have a temper bigger than me. LOL
I'm sure you could find a 3 foot breaker bar if someone needed to get broken
Hope I never have to do that.You're also a gearhead
They need to reel in the recyclers. I had to register to recycle more than 50 dollars worth of metal.Dealership I work at had the catalytic converters cut out of 10 trucks over the winter causing about $75000 dollars worth of damage.They we’re a well organized group of thieves, managing to avoid the security patrols.We also had a demo stolen from a hotel in the GTA near the airport. It was recovered about 2 months later at a port in Montreal.It had about $10000 damage to the dash,radio,wiring harness etc.RJ
Good point they should.They need to reel in the recyclers. I had to register to recycle more than 50 dollars worth of metal.
Hope it clears up not sure what it cost to rebuild injectors anymore.Well I took it out with the field cultivator and worked 6 acres. It still has a miss but I am hoping it clears up with a few heat cycles. If not I may have to get injectors rebuilt.
The pump was worn bad and needed the shaft even and it was 1,000 I think the injectors will be 150 to 200 each.Hope it clears up not sure what it cost to rebuild injectors anymore.
Yikes. Cant believe the price of fertilizer. I saw the writing on the wall and stocked up on nitrogen and sulfur. Skipped it on the lawn last year.The pump was worn bad and needed the shaft even and it was 1,000 I think the injectors will be 150 to 200 each.
We hang petty thieves and appoint the great ones to public office.
Politicians are the same all over: they promise to build a bridge even where there is no river.
A politician is a fellow who will lay down your life for his country.
Yes same here , 50,000 dollars in damages at the dealership here it’s everywhere,they have to go after the people buying them and it should stop ,just a thoughtDealership I work at had the catalytic converters cut out of 10 trucks over the winter causing about $75000 dollars worth of damage.They we’re a well organized group of thieves, managing to avoid the security patrols.We also had a demo stolen from a hotel in the GTA near the airport. It was recovered about 2 months later at a port in Montreal.It had about $10000 damage to the dash,radio,wiring harness etc.RJ
just got home from shopping. Did I ever mention I hate shopping.Morning men happy Friday!
Sounds good Mark pictures when ya get them on please.Hi guys. Hope everyone's day has gone well so far.
I've just 4 tires for my car. It was very touchy on the road and always steering it.
My buddy and I checked out the tires and the face on some of them are cracked so time to replace.
The good thing is getting rid of thos low pro-file tires. Look good but feel every dam bump. So they be about 1.5" taller on the back and 1" taller on the front and going from a 45 series to a 60 series. It's 9 1/2" wide on the back and 8" wide on the front. Probably installed late this week when it's not raining
With those kind of flotation devices, it's easy to go motorboating...
OK I'm up.
