Last one to post in this thread wins!
Ya got me on that one Mark. The first thought is a bad ground or alternator problem.
I thought that too and put a heavy ground from the chassis to the engine block. Someone will have the answer. I believe there is a voltage regulator on the back of the instrument cluster and wondering if that might be the culprit.
Could be :popcorn: Gonna stick around until someone knows the problem and figure it out.
I would check out the alternator Mark since the alternator supplies your vehicles electrical needs , when it begins to lose it's potential so does the vehicles accessories that draw on that electricity . Do your head light dim too? The regulator on the back of the dash cluster only runs the fuel and temp. gauge .
I did not know that FOG thanks I'm learning.
I stink at electrical but I think our A-bodies have issues where the wires plug together at the firewall too. Corrosion. They call it the bulkhead fitting I believe.
You missed this by two days Fred, way easier than going to Walmart! Right down the road from us, buddies daughter manages the bar.
**** guys I'm the only single guy here I feel alone and out of place most of the time.
