zkx14
Duster De-ruster
I never had to do it, but I recall someone posting a procedure to unstick the valve without opening it. Otherwise you will need to open the valve again and try to do it manually.
I am on my 3rd distribution block from online tube 1 leaked from the warning light plug and the other from the double nut leaking from around the washer I called again to inline tube they are replacing the distribution block again they told me they are having issues if this 1 leaks I'm getting my money backHas any one had problems with new brake valves leaking . I have a 1972 Dodge Demon did a brake conversion all factory parts new I have installed two new brake valves and both leak I know this one is not leaking at the lines I think at the top where the line from the master cylinder goes brass hex fitting or the hex piece goes into the valve
Thanks for reading this post Waco Demon
Yes new lines but there leak issue is coming from the hard washer on the 11/16 nut and at the electric brake warning light plug non of the brake lines leakNew lines? Did you use stainless?
I took my old valve and used the copper seal from it the new valves are from China and seals are bronze and are hard and will not seal .The valve from In Line Tubes was a piece of crap I got one from some one hear on for a bodies only and rebuilt it I had a slit leak at the light switch the light would glow finale it sealed is selfYes new lines but there leak issue is coming from the hard washer on the 11/16 nut and at the electric brake warning light plug non of the brake lines leak
